Bambie
- Mar 31, 2012
- 242
In my plant, a number of 900# 4"nps blind flanges have 30 year old spiral wound asbestos filled gaskets with outer compression limiting rings that are beginning to leak.
The process can be de-pressurized but not drained, so the following proposal is presented for comment.
1) remove a single stud
2) mill out the compression limiting ring between the two adjacent studs and flush to the raised face
3) replace the stud and torque
4) repeat until all studs are replaced, torqued and excess compression limiting ring is removed
5) peen the remnant (.158" wide x .125" thick) compression limiting ring face 360 degrees
6) check torques on all studs and adjust if necessary
Could this be successful?
