PDMLink help request: Cannot check part m
  • Thread starter Thread starter GearNuts
  • Start date Start date
G
GearNuts
Guest
I recently attempted to check some models into the CS but have not been able to succeed. It appears the models
have external references to other parts that are in a family table. When I look
at the models themselves I cannot seem to find the external references but when
I try to check them into the CS they pull up these other models which for some
reason will not check in either. Bottom line is I cannot check in the first set
of models because they appear to be somehow linked to a second set of models
which will not check in either.
I originally created the first set of models as
copies of similar models in the PDMLink environment. Apparently PDMLink maintained
some linkage to the other models (which are part of a family table) even though
it was not my intention.
I wonder if there is a way to discover these
external links and then delete them. I
