you can use external services to share the data and then put the link in the forum.
By default Pro/E(WF 5.0), Creo can pattern along curve (Pattern > Curve)
The old way to do this was to make a curve, point on it(Offset controled by "Real"), create a Datum Plane through this point, group them thogether, select the group and use dimension of point to control the pattern
Thanks for the reply. When using pattern, with the curve option, the pattern does not follow the curve.
Also, I've tried the "old way" and everything seems to pattern, except the feature. The pattern stacks the feature on top of itself. If you don't mind, I'd like to send this to you for review. my e-mail is wduffield.imse@gmail.com
