hi,
I need to make a drawing for a part that has a flat pattern in it (you can see a picture in attached file).
I want to know if there is a standard way to give a patterns dimension without going one by one and giving all the dimensions , for example in my part the distance between the holes is 14 so how do i avoid putting a 14 dimension between each pair of holes?
thanks.
thanks.
