PizzaEatingestSOA
- Aug 3, 2005
- 17
Right now I'm trying to put a dimple into a sheet metal part and patterning it. I'm getting the dimple from the library and then dimensioning it to the part edges.
This works fine.
When I go to pattern it, the first dimension doesn't allow me to reverse its direstion. After completing the pattern, no pattern is created. If I double click the pattern in the model tree, the first pattern dim goes off the part in the z direction instead of from the edge.
I've also had problems dimmensioning Hole Wizzard holes. Normal to the sketch is in the wrong orientation.
These problems all started today.
Has anyone else had these problems? Are they related?
Solidworks 2005
SP0.0
Window XP
This works fine.
Solidworks 2005
SP0.0
Window XP
