vaina
Marine/Ocean
- Jul 11, 2011
- 16
Sorry for my stupid question, but I found a (complicated) solution and I need some suggestions.
I'd like to create some holes along a 2D curve. In the sketcher I found only an Equidistant Points, but I want to set an 'easy' spacing between my holes (e.g. 50mm). I could obtain that with Point Definition and Repeat Object After OK, but resulting points are included in a geometrical set. If I want to apply the User Pattern command to a sketch (e.g. a circle) along the set of points, I need them in a sketch form! I thought to project all points and include them in a sketch plane, but maybe you can help me to find a less complicated procedure.
Thanks for your attention.
