CATIA measure along direction 2
Xaver
Student
Mar 24, 2025
4
Hello, I want to measure the maximum distance between a line and a surface along the z-direction (vertical). Is there any way to do that? All I get is shown in the screenshot attached. Please note the axis system for z-direction!
I haven't dealt with complex surfaces like that so I'm not sure, but the screenshots in this post may be helpful:
Thanks! That's not exactly what I need, I want the x- and y-delta to be zero. Verbalized, it would sound like this: "Return the maximum distance along the z-direction between the curve and the surface."
I would try the "Extremum Definition" under points.
Generate one Extremum point on the curve in the Z Direction.
Generate one Extremum point on the surface in the Z Direction.
You can toggle Max/Min to get the opposite results.
Then you can measure between the two points and get the "Z" component value.
If you want a 0,0,Z dimension, then create a plane "parallel through point" through one of your two points parallel to XY (normal to Z).
Then measure from the other point to this plane.
Thanks a lot! To clarify, I want to determine the maximum distance in z (and only in z) between the curve and the surface. So I'm not interested in the lowest or highest point of either the surface or the curve. If I were to draw lines from the curve to the surface in z direction, I would try to find the longest of those lines. Hope that heps...
See if you have "Distance Analysis" command might not be available depending on which license you have.
From top toolbar View>Command List
I left projection space as 3d and measurement direction in "X" (X for this model orientation, Z for yours).
OMG, that's exactly what I meant! Thank you so much! What a shame that the normal measuring tool doesn't include that option... Thanks a ton!
