mamebraso
- Jan 12, 2006
- 7
A foundation has been designed for a very high containment barrier on the depature of a bridge. Because the size of foundation is too small to resist sliding, a shear key has been provided. The question is, since the foundation is on the edge of the embankment and the only soil retained by the key is 3m of soil beneath the rest of the foundation and then the embankment falls off at 45 degrees, can you really consider the passive pressure provided by the key? If no at what distance can the passive pressure be mobilised. If it was ground level then you could consider it infinitely long. help out
