There is one way to link a part detail to an "item number" in a parts list, but it takes some doing.
On the first, I bring the assembly into draft.
Using property manager, you can assign a “dummy” item number to a property field of your choice.
You can then get this dummy number to show in place of the item number in the upper portion of the BOM balloon.
Click parts list, and then click on the view you wish to balloon.
Before placing the BOM, click properties.
Then, select the Balloon tab…
From here, uncheck use item number for upper text.
Put your cursor in the “Upper” field, and then click on the hand holding the letter “a” found just below the lower field.
From here, scroll and select the field which you chose to assign the “dummy” item number.
The balloons will now show this number in place of the item number generated by solid edge.
This way, you can sort your BOM according to what item or detail number you want each component to be assigned with.
Finally, select columns tab, and remove item number column, and add a column for the field you chose to add the “dummy” item number.
simply add that column to your BOM, and you should be set.
Finally , sort your BOM according to that field.
An added benefit of this is you can then place the "dummy" item number in a callout if you wish.
Just reference the property field you assigned the "dummy" item number to in a callout, and use graphic connection to part.
The callout will then reference the assy det # on other sheets.
To do this, select callout, and then select the general tab.
Click on the hand holding a letter "A."
Change the drop down option to "graphic connection to part."
To display item number, select the field you assigned the dummy number to. If you would like text to appear before or after the number, you can then type that into the property text box also.
For example a property text field as below
Detail Number: %{Comments}
would display the text
Detail Number: "and whatever is in property field comments"
-av8errrST3
xw46003GB
RAM2Quad CPU
3.00GHz
