Parts disappear in assembly drawing
JJL79
76
I have a large assembly. In this i create a section view of the assembly. I want one of the subassemblys in this view to be non sectioned but when i make it non sectioned some of the parts in the subassembly disappear. I have tried the 'interference' options on the 'Hidden Lines' tab of the View Style dialog with no success. Nothing seems to be hidden, nothing hidden in the view dependant edits.
I have tried to rearrange parts in the assembly to provoke changes in the view but this seams to just make other parts hidden.
This is a assembly with a couple of pretty large subassemblys.
What more can i do or check to try to solve this problem?
Im using NX 6
Have checked if your arrangements are all set correctly? Have you checked layer visisble in view? Check to make sure small features not being showed is turned off in your view styles?
There is no arrangements in this assembly
All layers are visible
I not sure about the "small features" thing, i have to check that as soon as possible.
Thank you SDETERS
Are you running the latest maintenance pack that is a known issue in early release
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.0.19(testing)
If you can think it it can be modeled
RyanVLee, how can i check if I am?
Go to help then go to about then You can find out what release you have.
Hi...
Maintenance pack (if any) is shown in green square.(attached image)
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
 http://files.engineering.com/getfile.aspx?folder=9fca1f1d-9541-44cf-8048-7498a3dc9be3&file=AboutNX.jpg
SDETERS, small features are set to "show all".
Thanks nutace, NX Patch is Unknown? NX Version is 6.0.5.3.
Forgot to tell you we also have Teamcenter if that matters?
It is important to note that there are maintenance patches (MP) and maintenance releases (MR). The patches are put out quickly to solve issues found in NX. A maintenance release is a group of patches (and possibly new functionality) that have been fully tested and are ready for everyone to use. So you may be up to date with the latest released code (the latest MR), but not show any patches in the Help menu. If you are running NX 6.0.5, you have the latest MR and are up to date (as far as NX 6 goes, anyway).
www.nxjournaling.com
