Hi All,
I couldn't find a forum post for the following:
When I download and import Step files from various companies, the imported parts are often composed of a *set* of Part Copies. Apparently I can only make one of these a Base Feature. Importing as Part or Assembly doesn't seem to offer a solution.
The problem comes in the Draft: there only the Base Feature is visible. I couldn't find any view property options to fix this.
Is it possible to make Part Copies visible in the Draft (or is there a fundamental problem, e.g. that they are not true solid bodies)?
Is the Feature Recognizer during import the only possible solution?
(although I try to avoid this, as the import procedure seems sometimes to get a bit out of hand)
Regards, MT
Regards, MT
