Hi All ... We are going to revamp the PSA for additional capacity. Presently the PSA tail gas is sent to surge drum and centrifugal compressor (two stage – 8 kNm3/hr ) discharges the tail gas to the fuel gas header. After revamp the tail gas system will have two surge drums and two centrifugal compressors ( two stage ) will be running parallely and discharges the tail gas to common header. The new compressor has the capacity of 21 kNm3/hr. When the two centrifugal compressor of different capacity ( 8 & 21 kNm3/hr ) running paralley do I need a load sharing controller between these two compressors .Does the two compressor need to talk to each other while running ?
