sinenhlanhla
We are having a challenge in the high lift pump station for the water treatment plant. 3 small pumps and 2 bigger pumps (vertical turbine pumps).
Pumps are operated as follow: 1 bigger pump (720mm impeller) and 3smaller pumps ( pump 01 365mm and pum02 & 03 are 376mm four-stage)
Most of the pump failure occurred on pump 02, thrust bearing collapsing most likely the cause of the pump failure and result in pump bottoming out and seizing up.
I want to conduct a study of why pump 02 always fails. Please advise.
