PA-NJ Turnpike Bridge Closed due to Fractured Steel Truss 6
bridgebuster's linked said:
It is clear that the fractured member was carrying no load
Gotta throw the BS flag on that statement.
How to explain the 2 inch plus displacement when the ability to carry the non-existent load was lost.
Bill
"Why not the best?"
Jimmy Carter
waross,
If you read closer, it is clear that the writer is talking about the condition after the truss chord parted. They were analyzing the bridge without that member.
It is clear that the fractured member was is carrying no load
Silly me. I stupidly assumed that the writer understood tense matching.
Bill
"Why not the best?"
Jimmy Carter
swall... if no one heard it, then, did it make a noise?
Dik
The answer to your question may be contained in the FHWA report linked by bridgebuster in his 22 Feb post.
FHWA Report said:
Incident: On Friday, January 20th at approximately noon, the resident engineer on the active painting job noticed that the upper chord on one of the PA deck truss spans was fractured. Second hand, we have heard that, when asked, the painting contractor reported hearing a huge noise and feeling the structure and surrounding ground shake back prior to Christmas.
Some one heard it.
It made a noise.
Bill
"Why not the best?"
Jimmy Carter
Looks to me that the hole is just for drainage. Fracture appears to be not related to it.
Amazing how straight the break is!
From Bridgebuster link report from FHWA.
really surprised at the lack of fatigue striations and the brittle fracture
Sawbux,
The holes referred to are the weld filled holes in the flange of the chord member, not the one that is open in the web.
The original was riveted. I've just been involved with a riveted bridge crane that material coupons indicated a high sulphur content... made it hot short, so welding was not to be considered for repair... could be the material is hot short and not weldable.
Dik
Or, each particular portion of that particular member comprising an uncontrolled and undocumented plug weld and associated HAZ comprise an alloy puddle of uncontrolled and uneven composition, some of which may be cold short, i.e., brittle at the temperatures encountered over the river on the day the big bang was heard.
... Okay, I'm not completely happy with that above, so I'll try again:
Each of the plug welds was not documented, and likely not controlled wrt to electrode selection other than using what might have been available in the shop on very short notice without leaving a paper trail. The remainder of the bridge clearly has a DBT low enough to have survived a fair number of NJ/PA winters, but the plug welds in the failed member presumably have a DBT a bit higher than would be suitable.
If a brittle fracture starts in a localized area like that, will it be stopped when it propagates into a less brittle portion of the same member? Would the member have failed if there were only one mis-drilled hole? Should there be some sort of transition visible in the fracture surface as a fracture that started in brittle material reaches slightly less brittle material?
I hope they'll preserve the fractured ends for study.
It sounds like the sort of real-world problem that, e.g., AISC, should suggest as a research topic for someone. Those are probably not the only undocumented plug welds in standing riveted bridges.
Mike Halloran
Pembroke Pines, FL, USA
My paper had this story
Link
Two quotes in the story by the Chief Engineer for the Pennsylvania Turnpike bother me:
[quote="It pretty much demonstrated a simple fact — that it's 1956 steel," ][/quote]
He should have qualified what he meant because there are people who will read it and think every 1950's era bridge is in danger.
Another statement that should have been qualified (bold text):
"it also is possible that an unpermitted load put too much weight on the structure, and temperature may have played a role"
Someone will think they shouldn't cross a bridge on a cold day. Granted, a lay person knows nothing about brittle fracture but as engineers we have to keep in mind how we say things.
itsmoked... as noted in the information included above, hot short basically means that base steel in the heat affected zones of the weld become 'brittle' when the welded material cools. This can be caused by sulphur being in the original steel 'mix'. This brittleness can lead to a sudden failure of the steel because it has a greatly reduced ductility. Once the failure is initiated, due to the reduced steel section, failure continues and can proceed very rapidly/catastrophically.
Dik
dik; Thanks much, I learned a bunch on that sword article and see what you're saying.
Glad I took a material science course doing Charpy and yield tests and being taught what 'body centered cubic' was.
Keith Cress
kcress -
Thanks for that link, berkshire.
Bill
"Why not the best?"
Jimmy Carter
Berkshire... Great link and a star,
You are welcome guys,
I learned about hot shortening and cold shortening in Metallurgy class in Technical College. It actually took me a while to find that article that described what I had been taught.
B.E.
Yes, thanks for a good link - My Spatial Reasoning isn't all that good and as a result, I have always found a lot of Material Science quite hard work. This guy comes at a few things from different angles that work quite well for me.
A.
