Hi guys,
I'd like to get some experience-based feedback on a problem we've run into. We're building heat transfer modules for a HRSG project that has P91 headers and fin tubes. We've checked hardness after PWHT on the base materials and welds, but have come up with many low readings (some as low as 160-170 BHN). As is common, we performed replications on these same areas to check microstructure, and the results have confirmed a uniform tempered martensite consistent with "good" P91. We've sent the micrographs to another lab for second opinion, but from what I've seen in the past it looks comparable to good material; no abnormalities that I can identify.
We've tried many tricks in the book to recheck the hardness (remove more decarb, recalibrate on block of P91, etc.), and results still come back low. Anyone run into this before? I tend to think the microstructure is the most important factor, meaning material is good, but haven't found explanation for the hardness testing. We double checked heat treat setup, tc locations, charts, etc. and it all checks out.
Any advice would be appreciated.
Thanks!
If it helps, the portable tester being used are MIC10/MIC20's with UCI method. Results reported in Brinell. And yes, we did PMI and confirmed it is P91 material
Thanks!
