I would like to know from someone if an incoming phase is burnt off will a three phase rectifier continue to operate and will this cause the rectifier to go into over load. Recently we had a phase failure and the rectifier diodes popped.
I know in a three phase induction motor, if the motor looses a phase, it continues to operate however if the motor is stopped and restarted, it movement operate.
Does a similar thing happen to a rectifier.
Specifications of rectifier:
Input voltage : 3.3kV
Output voltage: 3kV direct current
