I have designed a industrial motor base support. The structure is composed of a concrete pedestal, supported by a concrete slab on steel beams.
The crux of the problem is that there is an existing motor adjacent to where the new concrete will be placed, which produces noticeable vibrations. This existing motor cannot be shutdown for the concrete placement. I am slightly concerned about the vibrations over-vibrating the concrete and causing segregation.
Is there any literature about quantifying how much vibration is too much? (frequency amplitude)
I have thought about requiring the use of test cylinders cured in place prior to the actual pour, but are there any other measures (additives or mix design) that could help ensure segregation does no occur?
Thanks for your thoughts!
