the PSV outlet relieves to the atmosphere, so immediately i know the backpressure is 0 psig
however the outlet pipe + fitting will develop a pressure drop of 120 psig
my question is, what is my backpressure ? is it 0 or 120 ?
API 520 1.2.3.3 (J) built-up back pressure is the increase in pressure at the outlet of a pressure relief device that develops as a result of flow after the pressure relief device opens
so my actual question is whether the outlet pipe pressure drop is considered backpressure?
the turbulent flow generated at the outlet fitting is counted as backpressure ?
