Having limited log building experience, take what I have to say with somewhat of a grain of salt. I've worked on exactly one project, albeit with a true craftsman of a log builder where I learned a lot.
As some others have alluded to, these look like log infill walls between vertical timber posts - not a true log building. This type of construction is difficult to get right. Log shrinkage perpendicular to grain (as we all know so well) is very real. There are some good details around that allow the log infill portions to be connected to the timber posts for out of plane loads, while allowing for vertical movement of the logs as they shrink. There are also plenty of bad details that have been used over time and that result in the vertical posts carrying both out of plane loads, AND all the gravity loads once the logs dry out and shrink.
The shape of that bowed post looks quite buckle-ey to me. Combine that with what looks like a roof beam above, and my money is on the post being overloaded, and whatever connection exists to the horizontal logs being what is currently holding it from becoming the proverbial moose on roller skates.
