Out of date section view, no matter what is done
Engineering Saiyan
Aerospace
Dec 28, 2018
8
I have NX 9.0.3.4 MP15 and have an unusual situation.
I had created a projected view (using section view tool) and wanted to use a view break on it.
Only afterward I realized that NX9 has a bug where you can't really cut new sections through the view break without issues, so I removed the view break and proceeded to create the drawing.
Now that the drawing is completed the sheet that had this view break is ALWAYS out of date, even after you update the view and the clock disappears it will still be out of date as shown when trying to export a PDF or going to the sheets properties. This also shows up when you save, close, re-open the part since the out of date "clocks" are back in the part navigator next to the sheet.
I guess my question is whether this is a known bug and is there a work around without deleting the view and starting over? I'd prefer not deleting view since there are 7 views and 4 sheets associated with it.
As always, any help is appreciated.
You may need to re-associate the hinge line, or anything else related to projecting the view.
To do that you will need to Suppress the view break, ( you can do that in the Part Navigator
under the expanded Sheet) then re-associate what is required to make the projected view
work properly, then un-suppress the view break.
Jerry J.
UGV5-NX1961
