slickdeals
ASCE 7-10
12.5.3 Seismic Design Category C
Loading applied to structures assigned to Seismic
Design Category C shall, as a minimum, conform to
the requirements of Section 12.5.2 for Seismic Design
Category B and the requirements of this section.
Structures that have horizontal structural irregularity
Type 5 in Table 12.3-1 shall use one of the following
procedures:
a. Orthogonal Combination Procedure. The
structure shall be analyzed using the equivalent
lateral force analysis procedure of Section 12.8, the
modal response spectrum analysis procedure of
Section 12.9, or the linear response history
procedure of Section 16.1, as permitted under
Section 12.6, with the loading applied independently
in any two orthogonal directions. The
requirement of Section 12.5.1 is deemed satisfi ed if
members and their foundations are designed for
100 percent of the forces for one direction plus 30
percent of the forces for the perpendicular direction.
The combination requiring the maximum
component strength shall be used.
Does this mean that any structure in SDC "C" or higher should use a 100/30 combination or only structures in SDC "C" and higher (and) having Type 5 irregularity (non-parallel systems)? It appears that buildings that have walls parallel to the orthogonal axis need not use the orthogonal combination.
Thanks.
