Injection speed is dependent on the type of material and its ability to shear thin as well as the potential for surface defects caused by filling too fast thru sharp flow transitions. Start by consulting the materials supplier and then let the machine tell you when you are going too fast and limiting out the injection pressure. Slow it down, if you are getting jetting or surface delamination.
