GregLocock
Automotive
This week our team needs to throw together a good concept for a non-isolated subframe. We have various loadcases, and the allowable package, and the hardpoints identified. So far we've been running topology optimization using these load cases.
However, I would like to develop an optimum topology based on the /stiffness/ targets we have also set for many of the hardpoints. I've read various SAE papers, they mostly seem to be happy to optimise by increasing modal frequencies, or by improving the stress distribution. I haven't seen any references to people trying to optimise several stiffnesses.
I am rather confused, in that I am not sure whether to optimise the structure for each stiffness requirement uniquely, or whether I need (or can) use the entire set of stiffnesses as one loadcase. I don't think I can combine them, but if I treat each one as a separate case then I'll end up with a whole bunch of separate structures.
Secondly, I have some choice in the positions available to bolt the subframe to the chassis rail. I can use any 2 of four available on each rail. Obviously I'd like to concentrate my work on the most likely subset of mounting points, is there a way to eliminate the bad ones early in the analysis?
Thirdly I have always been puzzled by one aspect of stiffness optimization. If you consider the tip deflection of a simple cantilever then the sensitivity of the deflection to material along the length of the cantilever is biased towards the root of the cantilever, since the contribution of the bending stiffness of each dx slice is proportional to its distance from the tip times its local deformation. This means you should end up with a different optimum shape for stiffness than you would for stress (which is a parabola, I think, for a rectangular cross section beam). What is the name for this sort of contribution?
As you can probably tell, it is many years since I've done any serious structural analysis, and I'm a complete novice when it comes to optimization.
Cheers
Greg Locock
Cheers
Greg Locock
