Hi all,
I usually give my drawings the same name as my parts. For example:
MyPart.prt and MyPart.drw
If you have MyPart.drw open, and you do "File / Open", the file selection dialog box appears and it automatically preselects the file "MyPart.prt".
So, all I have to do is press OK and file MyPart.prt is opened.
I find that a very handy feature.
But unfortunately, that does not work the other way around.
If I have part "MyPart.prt" open and I open a new file, in the file selection dialog box the first file in the working directory is preselected, and not file "MyPart.drw", as I very much would like.
Is there a way to achieve this ?
I use WildFire 2.0
Best regards
I use WildFire 2.0
Best regards
