OpenDoc call fails!
jwalz
Computer
Apr 22, 2003
10
I am trying to write a macro that will go through all of my drawing files and extract the BOM information. When I execute the OpenDoc method the drawing opens, but I get the following error at the end of the method line execution: Run-time error '91': Object variable or With block variable not set and the call fails. I hope that someone can point out what I am doing wrong. Here is my code:
Set swApp = CreateObject("SldWorks.Application")
swModel = swApp.OpenDoc6(infile, swDocDRAWING, 0, "", swError, swWarn)
Where infile is the complete path and file name of the drawing file that I want to open.
Thanks!
Janet
simple VB omission. You need the "Set" keyword to set an object.
Set swModel = swApp.OpenDoc6(infile, swDocDRAWING, 0, "", swError, swWarn)
[bat]On justice and on friendship, there is no price, but there are established credit limits.[bat]
Thank you so much. That did the trick!
Janet
