open post processed file with custom editor
Primoz32
20
Is it possible to set a custom G-code editor as a default application to open post processed files in NX7?
I think editing this section in ugii_env_ug.dat should do
# This variable controls which text editor will be used
# when it is invoked from the KF class editor
# EDITOR=notepad.exe
Sandro Anderlini
Mould designer
Macerata - Italy
When you double click the file, you can set whatever editor you like.
If you want an editor to start when you finish postprocessing, that can be done at the end of the post. There are samples sround - check the NX post library or nx.cam forum.
I am curious - why do you need to edit the posted output?
Mark Rief
Product Manager
Siemens PLM
I dont need to edit output. I want to send it to the FTP site and add it in CIMCOEdit NC base. That is why i need external program - just to speed things up.
Can this be done in Postbuilder? How? I didnt find any settings like this. Should it be coded in TCL?
Hi guys,
Maybe with a macro or a journal,
or C++ program, you can launch Cimco edit.
I want to know, it can be usufull to send programs by DNC.
Thanks.
You could consider to copy it to the ftp server from the postprocessor or execute an external command from within the postprocessor. Executing an external command is not as stable as a copy/rename. If the user waits too long or clicks a bit too fast the whole nx session will stall.
