Let's say I have a commercial box building, 55' wide x 150' long x 20' high. Steel frame, bar joists with metal deck clear spanning the 55' with wide flange girders and 6" tube columns and light gauge infill. I have chevron bracing on both 55' walls and on one of the 150' walls. The front end is all storefront. The chevron bracing and diaphragm are stiff enough so that any sort of moment frames I put on along the storefront side take little to no load and my chevron frames can take the torsional diaphragm forces no problem. My question is should I still include some moment frames along the storefront end for general stability purposes, or just go straight pinned with all the connections? I'm not completely sure what the general practice is here. Also I'm not in a zone with no seismic and low wind.
