I am working on a circuit to emulate the output of a speed/position sensor on a machine. The sensor is a magnetic pickup that reads a wheel that has 8 evenly spaced teeth with a 9th tooth for position indication.
The output of the sensor swings from +15 to -15 volts for each tooth. I have coded a microcontroller to generate the proper timing for this pulse train, but am having trouble with the output circuit.
I can easily make two outputs from the uc, one for the positive half of the wave and and one for the negative half. Is it possible to drive a single opamp (say a TL082) as inverting and non-inverting?
My background is programming not EE, getting hung up on the hardware side of things.
