Greetings,
I've been experiencing sparodic op amp failure (shorting the power supplies is one failure) in one of my designs. The op-amp (OPA 2277) is being used as a buffer. I was made aware that it is possible to that the inputs are getting a voltage before the power supply pins are. What is the best approach at handling this. Are there other methods besides using Schottky clamping diodes at the input and supplies?
