The above circuit represents my current configuration. The circuit is used to measure a ± 10.0 VDC signal.
R2 prevents my circuit from floating and provides a good high impedance.
R3 and R4 is a voltage divider that reduces the ±10.0 Volt signal.
Someone recommended on this forum, that I put a resistor on a Unity gain buffer. (R1)
The issue is that I am not getting full swing on "NODE 1" when the voltage is negative.
I've changed op amps
OPA2277 had the biggest difference of about 0.030 V
OP296GS had a better difference of 0.007 V
Basically at ± 10 I am getting +10.000 and -9.993 (OP297)
Can someone shed some light on the characteristics of opamps that I am somehow missing.
Thank You,
morizabal
