I have a renovation going on with a building from the '50s. The existing floor system using a precast joist system called F&A. It is an inverted tee concrete joist with a precast panel between them that is topped with concrete.
The drawings call out an 8" F/A Joist #867. I am trying to figure out the capacity of the joists. I was told that the first number is depth and the second number is allowable pounds per sq. foot. So the #867 would be 8" deep with an allowable load of 67 psf. I have no idea if this is true. If anyone can help that would be great. Thanks in advance.
