Ok Apply Cancel Buttons. in setting they enabled but in dialog they don't
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
As shown in this picture the Ok Apply Cancel Buttons are enabled
but in dialog they are disabled (only cancel enabled)
Then someone can help
Thank you.
I can open two nx sessions and
rebuild the dislog by copy past.
But I think it should be
a way to correct this.
I see now that adding a face collector or body collector cause the ok apply buttons to be disabled.
when start the buttons are enabled but
when adding a face collector the buttons are disabled
So what I do if I need these collectors.
The behavior would be that there is nothing to OK or Apply when nothing is selected yet. So the buttons should become available once you have selected a face or a body.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hi NotAce and thank you.
I know that but because selecting a face
not make the ok or apply to be active.
I was confused.
but only now I tried the select body
(I have 2 collectors face and body)
and that make the buttons active.
conclusion must be play around more time.
do you have a thought why select face
not make the buttons active.
Thanks.
enableOKButton_cb
Now I see this routine in my generated code
how I can use it to force ok apply buttons
to be enabled/disabled.
I used the collectors without to get
the propertylist and property dispose
and property nothing.
and the code work.
do that can make problem.
In Enable OK/apply Button False
and Enable OK/apply Button True
what is the difference ?
In my example I don't see any difference
Thanks in advanced
