Offset > Expand feature : tiny failure
  • Thread starter Thread starter muadib3d
  • Start date Start date
M
muadib3d
Guest
seems Offset > Expand feature > Options > Translate - does not keep tangency between translated surfaces
I wanted to move exisiting solid geometry - example on pictures below. At the end Creo did it but moved surfaces failed to keep tangency between them
just an information for others
I was unable to duplicate the issue in Creo elements/pro 5.0 (Pro/E 5.0). Is this a problem only in Creo 1.0-2.0, or am I missing something?
Nate
it seems it is certain issue for Creo 1.0 M010.
I was informed that in WF 5.0 and Creo M050 this issue does not occur
