hailtopitt
Chemical
Hope someone can help brainstorm an idea with this one.
Running a 20" carbon steel pipe about 600 ft in length which ends up dumping into a separator at the end of the line. Gas is, on a dry basis:
80-85% H2 and CH4
10% N2
<2% O2
3-4% C6H6 and derivatives
3-4% H2S and HCN
(Percentages don't add up perfect but that's the general range)
Gas is also saturated with water due to the gas compressors. The separator in line is meant to drop the water out (so I guess you'd call this a wet gas line). The line is 30 psig and 180 Deg F.
The problem we've seen is that the piping has recently begun corroding at a very high rate, and only at the top of the pipe. The wet area experiences little thinning and the water system itself also sees nothing.
Almost nothing has changed, the only notable thing being the removal of excess NH3 from the system. The water in the separator used to run a pH around 7.5 because of the extra NH3 but since then, it has dropped to about 5.5-6. I could see this as a problem, except the wet area isn't what's seeing the corrosion.
Is there an anomaly where the condensed water (ie) droplets on the top and side) could be even more corrosive than the bulk water? I feel like I'm grasping at straws there. Any bright ideas?
80-85% H2 and CH4
10% N2
<2% O2
3-4% H2S and HCN
