I'm looking at an elliptical manway application in a pressurized tank, which is IAW Section VIII, Div. 1, and as part of the assembly there are bolts that are used to tighten the manway cover to the ring and seat it on the gasket. My question is whether the bolts, which are outside of the manway, fall under the jurisdiction of the code and hence must be a code bolt material and have code allowable stresses. The bolts are used primarily to position the manway as well as acheive an initial gasket seating load until the internal pressure takes over and pushes the manway onto the ring enough to seat the gasket on its own. There is some negative pressure considerations for the case where the unit trips and the tanks drain into the condenser.
Its an odd sort of case because the pressure relieves the bolts rather than trying to pull on them further and at working pressure the pressure itself is responsible for maintaining the pressure boundary on the gasket not the bolts.
Any help would be greatly appreciated so I can sort out what the real allowable stress will be in those bolts. Thanks.
