We want to use some small o-rings, probably -011 (OD .441", .070" thickness), durometer A70. There will be a c'bore in a plate in which the o-ring will be placed. We want the OD of the c'bore to be slightly undersized such that when the o-ring is placed in the c'bore, it will stay in place when the plate is flipped upside down (for assembly with other parts). Any suggestions on how to size the c'bore to make this happen?
