the shape of the enclosure is oval cone,overall size )62 * 56 oval * 100 length), the cap or (lip)is at the bigger end, the shape is hollow with 3mm wall thickness, the lip is simply an oval 3mm thick Al sheet with 4 drilled holes for the screws, there are 4 * M3 screw to fix the lip to the enclosure, the screws holes are placed within the oval shape, the o-ring groove is in the oval cone part as shown in the picture, the T1, T2, and groove width (W), if I use 1.5mm o-ring that requires 2.2mm groove width , then the remaining width of the wall (within the groove depth) will be 0.8mm. So my concern is, if I made T1=T2=0.4mm , will the (T2=0.4mm) withstand the force due to external pressure (20 KPa) or will it fail (break or crack)?
