I am using the NXOpen function AddToDeleteList to delete feature construction geometry. This function works well and deletes the construction geometry; however, it is not deleting the expressions associated with these deleted features. After running the NXOpen routine, the expressions within expressions editor can't be deleted manually either. When trying to delete the expressions manually NX says the expression is assoicated with a feature.
How can I delete unused expressions with NXOpen?
R/ WEJ0901
R/ WEJ0901
