NX9 - Journal to import to CSYS (wherever it is placed) 1
Kenja824
Automotive
Nov 5, 2014
950
When I record a journal to import a part file, it will only bring the file in at the same point it did when I recorded it. Even though I recorded it to come in to the csys. Can someone help me with how to import a part file so it comes to zero zero of the csys in modeling no matter where the csys is placed?
Let me correct myself here.... I want to bring the part file in at the 0,0,0 of the current WCS position. Not at a csys.
Here is the code I recorded...
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: File->Import->Part...
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
Dim partImporter1 As PartImporter
partImporter1 = workPart.ImportManager.CreatePartImporter()
partImporter1.FileName = "R:\hms_tools\NX9\Tooling\part\ZERO DOWEL\ZERO_DOWEL.prt"
partImporter1.Scale = 1.0
partImporter1.CreateNamedGroup = False
partImporter1.ImportViews = False
partImporter1.ImportCamObjects = False
partImporter1.LayerOption = PartImporter.LayerOptionType.Work
partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
Dim element1 As Matrix3x3
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim nXMatrix1 As NXMatrix
nXMatrix1 = workPart.NXMatrices.Create(element1)
partImporter1.DestinationCoordinateSystem = nXMatrix1
Dim destinationPoint1 As Point3d = New Point3d(0.0, 0.0, 0.0)
partImporter1.DestinationPoint = destinationPoint1
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
Dim nXObject1 As NXObject
nXObject1 = partImporter1.Commit()
theSession.DeleteUndoMark(markId2, Nothing)
partImporter1.Destroy()
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Ah, I think I found it. I found a similar code out there and it worked for me. I made the following change in my code and it seemed to work.... almost..... It turns out that this brings the part file in at 0,0,0 to the WCS, but if the WCS is rotated, the plane the file comes in does not move with the WCS. If anyone can help with making the file import on the XY plane of the WCS, I think I would have what I need.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
element1.Xx = 1.0
element1.Xy = 0.0
element1.Xz = 0.0
element1.Yx = 0.0
element1.Yy = 1.0
element1.Yz = 0.0
element1.Zx = 0.0
element1.Zy = 0.0
element1.Zz = 1.0
Dim destinationPoint1 As Point3d = workPart.WCS.Origin
End Sub
End Module
Your code above creates an orientation matrix that is aligned with the absolute coordinate system. You can access the orientation of the WCS and use that instead.
Change this code:
Code:
to this:
Code:
partImporter1.DestinationCoordinateSystem = workPart.WCS.CoordinateSystem.Orientation
After making this change, you can eliminate all of the (now useless) "element1" code.
www.nxjournaling.com
Awesome Cowski
This seems to have done the trick. Thank you very much.[thumbsup2]
