NX9 Geometric Constraiints 2
Jaydenn
281
Hi all,
Can I turn the geometric constraints back to the NX6 workflow?
The NX9 method of choosing the type of constraint first is absurd to me... I like the method of choosing the geometry first, then having appropriate constraints shown to me.
In NX9, 100% of the time, I ruin my sketches because I immediately start choosing geometry and it applies bogus constraints.
So many of the enhancements in NX9 seem oddly backwards. and time consuming. and take more clicking.
Is it just me??
J
NX 6.0.5.3
That behavior of selecting geometry first and getting the available constraints is still valid for NX9...
See attached movie...
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
 http://files.engineering.com/getfile.aspx?folder=161262cf-9077-4564-b306-eade7e26407f&file=Constraints.wmv
The mistake you do is to start the constraints dialog.
pick the geometry ONLY, no command, and you will have both a popup and a "toolbar" appear next to the cursor.
Then you get "the same" as NX6, but without starting the constraints dialog.
Then , in some odd cases you can/will use the "C" ( Constraints) dialog.
Tomas
That's amazing. As always, Eng-Tips to the rescue!
Thanks everyone.
Jay
NX 6.0.5.3
