brymat93
Automotive
- May 7, 2015
- 1
I am having a problem detailing some parts in a job assembly. This is the first time I have ever had this problem. I already detailed a part from the same assembly within the displayed part like always. and started to work on a second part in its display part, I set up the sheet, placed some views, and when I try to dimension anything on it (holes, horizontal, vertical, rapid dimension) it shows the proper dimension while placing, but after clicking to select the placement it disappears? I cannot select it at all after this happens it is just gone. I checked the layer settings and everything is on. I checked the color settings for the background and the dimensions and that is not a problem. I am stumped, any direction would be appreciated!
