Hi everyone!
Here are some issues I've come across when I was trying to create my first Grip code.
My idea was to create a .grx that will automatically put all UG objects to the layers where they should end up (datums->61, sketches->21 etc.), no matter if they are on a selectable layer at the moment or not.
And here are the questions:
1.Which object type number is assigned to the Sheet Body?
(I use MASK/ statement and don't want to make Solid Body
selectable as well-ONLY sheets)
2.When I put all the "134-SKETCH" objects to the particular
layer there is still something left. I gather that sketch
contains some more objects apart from "134-SKETCH".
What are these objects?
Thanks in advance and best regards
mateusz (matthew)
mateusz (matthew)
