NX2406 Dock Resource Bar on Second monitor
SDETERS
Agricultural
May 1, 2008
1,306
Did they remove the option to dock the Resource bar on the second monitor in NX2406? Thanks.
No, it still working.
Best regards
MANok
Thanks, Where is this option located at>?
Perfect thanks for the help, It looks like the resource bar can not be docked on the second monitor. If it floats, when applications open, they are hidden behind this resource bar. I must be missing something.
Hello
First: sorry, i was thinking about Tab from Resource Bar, not about Resource Bar. My fault.
Second: I was try make Resource Bar as float and after I was place it on second monitor.
First tab I left as Resource Bar, and two others I undock and places next to the first:
First time, when I change Application (from gateway to model) Resource Bar was hiden by Tab, but when I close it and select one again this starts work good.
And after I haven't problem with this.
Best regards
MANok
NX2027
TC14
How did you dock the window on the second monitor, and not have other applications not be hidden under the resource bar?
I don't know. Simply I just did it:).
I think - solution is Resource Bar with option "Pin open", and first tab as element of Resource Bar, no like a separate Tab.
Best regards
MANok
NX2027
TC14
I had some discussion with Siemens support and there is an ER 11155631 that exists for this issue. Thanks for all of the help and feedback.
