NX - UI Blocks - Dialog error
Obito
6
Hey,
For a while I've been trying to make some dialogs for school, but I'm having this issue.
When I go to the "Block UI styler", the "Dialog" window doesn't pop up (or it does & closes really quickly).
I've tried it on other computers and there it does work, I'm not quite sure what could cause this. (The Pre-NX6 styler works just fine..)
(I've added an attachement showing what doesn't appear)
Any hotfixes?
Thanks in advance!
 http://files.engineering.com/getfile.aspx?folder=0b872d07-4982-4bab-9248-2398a6288624&file=Error.png
The X & Y positions of the dialog may be outside of your desktop resolution.
For NX 8.0 these positions are stored in the following registry locations
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\8.0\Layout\BlockStyler\x
HKEY_CURRENT_USER\Software\Unigraphics Solutions\NX\8.0\Layout\BlockStyler\y
I think you are in NX 9.0. Check your registry and see if there's a corresponding value for your NX version.
If they exist, compare the values with you desktop resolution.
If they are bigger, you can change the values to a smaller number.
HTH
Hey Apekas,
This solved my problem.
Thanks and have a nice day!
