Hi
Can someone help in this
when I reorder the sketches in the part navigator
the order in the environment sketches list do not change.
Thanks in advanced
I clear my question
with timestemp checked I create a sketch and draw one circle
I exit sketch task environment and create another sketch
and draw a rectangle with no constraint and exit sketch task environment
now in part navigator i have 2 sketches in this order
sketch0000
sketch0001
this also seen in the same order in sketch task environment
now I drag sketch0000 to be below sketch0001 so in part navigator I have
this order
sketch0001
sketch0000
but in sketch task environment the order is still
in this order
sketch0000
sketch0001
and I expect that the order to be the same as part navigator
I mean in the drop down list window next to task enviroment flag
theire the list of sketches refuse to change when I change
the order in the part navigator the drop down window list is the same.
I believe that the drop down list is sorted alphabetically and has no relation to the part navigator. I suggest giving the sketch a meaningful name when you are in the sketch task application; this makes the part navigator and the drop down easier to use.
