Hello
I have NX 8 and I have a problem
here is the thing:
I start a new file from template, with "model template".
In file I have a e.g. solid body, for example on layer 5.
Than I make drawing of that body.
Go back to model environment.
Then make an extraction of that body on a different layer which is also no need to be active or work.
Than if I go back to the drawing (with new layer / body inactive in layer controls) I got drawing with that new body included, which is not OK of course and very irritating because all drawing made before are useless.
Also that thing happen if I import any body (instead of extracting) to the part with existing drawings, the drawings also includes that new body.
All that thing is not happening if I make new part file with "blank" from template.
Anybody know the solution to the problem?
Thank you
D.
here is the thing:
Thank you
D.
