NX 8.5 FEM Rotation
powpow5
Aerospace
Jun 18, 2014
4
I'd like to add a rotation load on a disk (I want to know the deformation of the disk when it's fast rotating). But I'm not able to add a rotation load to my disk. I can choose a vector or a point but not the object itself.. It's also impossible to pick the disk first and then add the load..
I'm grateful for any advice!
Maybe add more detail to your question, a screenshot, or an example file?
attached you find a screenshot of my situation when I try to add a rotation load.
Im confused because there is a green check at "choose object" meanwhile there is a "0" for chosen objects?! I cannot pick my disk in this configuration?!
Best regards
 http://files.engineering.com/getfile.aspx?folder=c6a65344-02b9-4ddd-a969-49b700e2970a&file=fem001.png
When I apply a centrifugal load, I get the message "Centrifugal load will be applied to the whole model, selection is complete". I then only have to specify the vector, point, and desired values. I think the Select Object (0) prompt is normal and working as intended.
same goes for gravity load, no need to select an entity at all because all nodes will be loaded.
kind regards,
Tuw
