NX 8.5 drafting template
aleksandar81
137
I made drafting template and then update ugs_drawing_templates.pax and ugs_sheet_templates.pax files.Everything works fine if I use master model,my templates are there,but if I wannt my drawing to be in part file I can't have my templates,I see the preview of them but the sheet is empty.
i do not understand the question, can you upload an image or try describe the case again ?
Tomas
If I am correct, the situation where it doesn't work, you are just switching from modeling to Drafting in the same part? (without creating a new part?)
Then he answer is simple...You don't get the option to grab a new template because you are working on the template of your model...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
@nutace
But how then I do have Siemens drafting template,if I'm working on model template,and why do I have preview of my template?
Can you make a short movie in NX of what you are doing?
NX9 / TC10.1.2
HP Zbook15
Would be nice to know the solution....Others can benefit from that information
NX9 / TC10.1.2
HP Zbook15
