Nx-6 Referance Set
Spannala
Petroleum
I have arrayed the solid body by using the instance geometry feature.
Added these arrayed objects in named referance sets.
No. of arrayed objects are 4.
When i am changing the no of arrayed objects (Lets say 6), the 5th and 6 th objects are automatically not added in to the named referance set.
We need to do that manually.
Is there any option is available, so that the new arrayed objects automatically goes to the named referance set
The only Reference Set which provides automatic propagation, like you described, is the 'Model' Reference Set. Any additional Reference Sets created will only contain the objects which you explicitly indicate as being included in that particular Reference Set. This behavior is 'by design'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You can have Add Components Automatically toggled on, but you need to make sure that if there are components in that file that you don't want in the reference set you need to deselect them.
But in this case, the OP was talking about objects in a Part model, not Components in an Assembly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
