NX 10
LayKanae
Industrial
Jul 28, 2014
23
Hello everyone!
I guess the majority already have some knowledge about the launch of NX10!
I'm excited because I saw that this new version has some improvements in 2D,
However... Does anyone know if it has improved the creation of drawing templates?
Faster and easier ways of doing custom templates
So far I have applied different methods which are usually long and impractical, besides having to make templates for each sheet type, because I when resize the sheet... the formatting is lost
I've seen some friends perform the same templates in Inventor and make it so much easier
In NX10, the title block will reposition automatically when the drawing border is changed, so if the sheet size changes, the title block will reposition.
From that I can't see why you can't make only one template for all possible sheets sizes.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Hello Jerry1423
No, we do not use Teamcenter
Hello Phoenx
We designed a template per sheet because the title block was not kept in position when resizing ...
In addition, block size title must change according to the size of sheet
